Configures the MLD snooping leave timeout.
| leave_timeout_ms | Specifies an MLD leave timeout value in milliseconds upon receiving an MLD done message. |
| vlan_name | Applies the configuration only to the specified VLAN. If no VLAN is specified, the configuration applies to all VLANs. |
| vr_name | Specifies the VR to which the configuration should be applied. If no parameter is specified, the configuration is applied to the current VR context. |
1000 ms.
The range is 0–175000 ms (175 seconds). For timeout values of one second or less, you must set the leave-timeout to a multiple of 100 ms. For values of more than one second, you must set the leave-timeout to a multiple of 1000 ms (one second).
The specified time is the maximum leave timeout value. The switch could leave sooner if an MLD done message is received before the timeout occurs.
The following example configures the MLD snooping leave timeout to 10 seconds:
configure mld snooping leave-timeout 10000
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
